Rear coil height
jonb2
Member
Hi. 2007 4runner V6 2wd. Looking to replace the oem rear coils with a lift coil. I need to find out what the approx height of a stock new coil and how it compares to mine which are about 14-3/8" tall now. Any idea what the approx stock height is on factory rear coils?
thanks!
The amount of lift you get depends on both the spring rate and size of the spring. Just comparing the height of aftermarket vs stock wont tell you how it'll sit once they're installed.
Dobinsons is the best for coil springs IMO for these trucks. Different height springs / spring rates will affect the ride quality. Dobinsons is great for giving a break down of the lift you will achieve and the weight needed for those coils to ride properly (stock, light load, medium load and heavy load options). Let us know if we can assist or if you have more questions !
erinobr2000
