Nelsonmd
So I finally got to work on my pastor's 96 LTD today, and I found the source of his rear diff leak. It wasn't a rusted housing like I thought, but rather the lowest diff carrier nut was barely hand tight, and most of the others were only a little more than hand tight. I looked up the torque spec (74Nm, 54 ftlbs) and went at it with my torque wrench. I ran into problems when the lock washer under the nut began to spread apart, and as I tightened, I forced the nut into the lock washer, then the socket slipped on the nut and mangled the nut a bit. I wasn't near the torque spec, but I didn't feel comfortable doing any more. The next nut did the same thing. The rest I just hand tightened as much as I could with a regular wrench and left it as that seemed to not cause the problem
Here's a pic of the nut...
For what it's worth it looks like the leak is mostly stopped, so that's good, but I would like to know what is going on here. I am going to try to find the nuts from my old diff and swap out the mangled one, but I can't find them right now, so it has to stay put for the moment.
I was planning on dropping the diff and putting in some right stuff to re-seal it, but I prefer this route if it works as I can't keep their vehicle very long because it is their only one.
Anyone know what is going on with the nut and washer?
