Rear diff thrust washers
cordrayj1
is there somewhere i can buy just the new thrust washers? i think mine are WORE OUT bad. takin my aussie out the 4runner this weekend to check backlash and wear pattern and wanted to replace the thrust washer/spacer at the same time. . .
Duffman is thrusting in the direction you can get your washers!
ECGS or the local toyota dealer.
More then likely, if your pinion depth and preload is ok then you don't need any spacers, crush sleeve or thrust washer. You just need to move the carrier closer to the pinion to get rid of the back lash.
Please keep in mind that this is my opinion and that i may be totally wrong.
