2005 SR5, V6 4WD, 107,500 miles
A few month ago, I'd some bearing in the rear diff replaced to fix whining airplane like noise problem. All the differential fluid (center and rear) was also replaced with Mobil 1 Synthetic. It just caught my attention that the oily watery puddle on my garage floor is right beneath the rear diff. This might have happened for a while by now. I took some pictures. Both the "pumpkin" rear diff module and the underside and back of the skid plate to its left (looking from rear) look oily. How do I check the fluid level - should I check both the rear diff and center diff (transfer case)? Do I run a lot of risk wrecking the diffs if I keep driving it? I am going to see the mechanic who did the work this year next week but I want to find out what's going on before then by myself if I can just check the fluid level. Is there any light if the fluid level is low or , a stick measure like the engine oil ?
Please advise. Thanks.
