Rear differential fluid.
kman55
I haven't changed mine since I owned it, a couple years so I'm slacking on maintenance, but that's going to change. I saw that it wants GS-5 SAE 90. I have gathered you drain, fill until I slowly drips out plug and done. I am wondering what everyone is using, brand wise. I have heard good things about the amsoil synthetic. Thank you in advance for any help. Just trying to catch up on maintenance... Loooong overdue!
I've got Lucas Oil synthetic in mine. Works good. I've heard a lot of good things about Amsoil, but I wanted something that I could just pick up at the automotive store. I figured with synthetic, I could go 5+ years between changes. And even though it's a very simple drain and fill, it's just one less thing to worry about if you go with synthetic.
The biggest tip when doing this is to remove the FILL plug before the drain plug. Should the fill plug be rusted or too hard to remove, you haven't yet drained out the fluid.
I use Amsoil sever gear 75w-90 in the front diff, rear diff, and transfer case.
X2 except I have been using Mobil 1. Do not over fill by filling with the back up hill. This allows excessive oil to be at the axel/wheel seals.
If you have a manual trans, do not use a GL-5. Use a GL-4 only. It has less sulfer which can damage the brass in the transmission.
x3...
Far as oil, brand doesn't really matter as long as you get the right one, and change it properly (i.e., don't consider it a lifetime part. I think the interval is 30-50k miles). I mean, don't get some uber cheap brand only sold at sketchy store with their name hand painted directly on the building, but any name brand should be fine. If you want something fancy you could use an oil with Moly in it (I might try this next time, I saw they sell moly oil at NAPA), but you aren't going to notice a difference no matter what you use, as long as it is the right thing.
Like Gerdo said though, that only goes for the diffs. Manual TC/Trans is a different animal and going low quality may affect your performance.
Also, consider getting new metal gaskets for the plugs when you do this. You don't have to replace them every time like the manual says you do, but if they are worn, been drained and filled a couple time without replacing it, then you might get a very slow leak; they do wear out. They are pretty cheap from a dealer, or a shop you take it to might have some generic ones on hand.
X4...if I had not done this I would currently have no fluid in my front transfer case. I got the Amsoil. Severe Gear oil from NAPA fyi. Auto Zone, O'Reilly, Advanced Auto Parts, and Pepboys did not carry the Amsoil.
Thank you guys for all the help! If the bolt is too rusted is it okay to try se pb blaster or something to get it off?
Yeah, Pb blaster is fine. If the plug itself is rusted, consider just buying a new one. I don't think they are too expensive from the dealer.
I cleaned mine up with a dremel, then used a 15/16 socket as cleaning it off made it a little bit smaller.
That seems correct but Im not sure you can actually drain out all of it. 2.9 would probably be total capacity if its bone dry. So Probably the answer might be 2.5? maybe?
Those big plugs have a low profile and round off easily. I strongly recommend using only a six-point socket or you will round off the corners if it has been in there a while. PBblaster the night before, a few hits from a regular hammer to break it loose, and mine came out using a 6-point impact socket on a breaker bar.
Oh yeah, did anyone mention doing the fill plug first? :)
That's a good point thank you! Yeah lord only knows how long it's been on there. I doubt the previous owner did it, mid twenties girl. Yeah I have read about people draining and not being able to refill! That would be a easily ruin a day haha
Sorry if this is dumb, but you it being topped off is when it starts dropping out correct? That seems to be the general recommendation.
Ya you fill till it starts coming out the fill plug, but make sure the truck is level as you'll get too much fluid if you only jack up the rear.
Thank you, do you use the 75w-90, I believe I saw 80w-90 was for the front. Or is it preference since it says only sae 90?
Talyn
