Rear differential Knock
gmata
Sorry for posting all this different problems i have with my T4R.
Any ways when i go to Park after driving for a while after i take the foot of the breake pedal i can hear a loud knocking sound coming from the rear differential.
Any ideas what could be causing this?
i dont see the need to replace them if they are not worn out. there are a bunch of zurt fittings on your drive(prop) shaft both the main and the front(for the 4wd). i would give them each about 5-6 pumps each then drive it for a few days and repeat untill the noise goes away. make sure you drive it in 4wd too(4hi is fine) so the front shaft gets greased
lindwlson982
