Rear Gate Problem!! Need help ASAP!
iAlex684
I just got out of class and was heading to work then my rear wipers turned on randomly I checked the switch and it was on the off position. After a minute or so the wiper went back to down and turned off I tried opening the rear window and it wouldn't go down until I kept pressing it. When I put it back up the wiper turned on again. Now my rear gate will not open when the car is on or when it's off. I need help getting this fixed I tried searching on the forum and Google and tried looking in the manual for a fuse.
First off how did you "test" the battery and what were the results vs. its CCA rating?
I suppose you could try rolling the rear glass up and down 3 times to see if it needs to be reinitialized. Otherwise it could be an issue with the rear door module...
I had a battery tester hooked up to the positive and negative post went through at the steps it was 710 CCA and the tester made me check the temp of the battery then it tested. After a couple second the result said it was good.
DionicioLives
