Rear housing question
hurt4x
OK so I just scored a complete 99' 4runner e-locker rear in what I was told to be the 4.10 flavor. Not really worried about that, I can count teeth to confirm.
My question is will the drums, backingplate and axles out of my 98' v6 auto. fit into this 99 elocker housing? Reason I ask is because I just put $800+ in axles and bearings into my current rear and would like to just swap them to the elocker rear. Not much came up on the search function
I appreciate any info!
Yes, everything will interchange. The only difference in terms of 3rd member bearings is one of the carrier bearings is much larger. That bearing is most easily available from Toyota, it is just a Koyo bearing.
If you have ABS, are your wheel speed sensors located at each housing end?
I can't remember if it's just the Tacoma's that have a speed sensor on the 3rd member for non E-locked rears.
jisoo200
