Rear license plate thingy
NoWayOut
Member
So I just received the plates for the wife truck, went to put them on and was like wtf.
Is everyone just bolting the plates right up against the paint?
I just cant do that.
Do they make a piece that the license plate can lay against so it doesn't scratch the paint?
Just picked up this last Friday. I have always just mounted the plate directly to the truck. But, I like the temp plastic dealer plate idea. I also always go to the Depot or Lowes and pick up some stainless button allen head M6 screws to replace the factory. Won't rust, looks better, and adds a bit of extra work for anyone who might want to commandeer them. They are machine thread screws and work just fin in the front plastic mounting piece as well.
^Great idea.
Hey do you guys slice up your reg stickers after putting them on in order to foil thieves?
I just put my new sticker on but didn't cut it up this time, yet.
:angel:
I’ve used this same one for the last 4 or 5 years. Works great. Keeps the plate clean and no marks on my vehicle. Just moved it over to my new 4R. Probably will plasitcoat the brushed steal for this vehicle.
License Plate Covers - Clear Cover Waterproof License Plate Protector | WeatherTech
Just remember:
Clear covers may not be legal in all states. We recommend reviewing state and local laws prior to purchasing a WeatherTech ClearCover. You can view information regarding state and local laws by visiting the website of your local department of motor vehicles.
Just remember:
Good point and suppose that is true. Never had an issue here in Michigan or any of the other states I’ve driven through in the past 10 years.
^Great idea.
:angel:
What is this slicing-up sorcery of which you speak?
PA stopped issuing stickers, but they used to come pre-scored with basically an asterisk shape across the sticker. They would peel off the backing just fine, but would tear into small pieces if you tried to scrape them off of the plate.
Put 2 rubber grommets in the plate and then put bolts trough it. It is water tight and gives you soft point of contact with paint.
I ended up using some stick on foam pieces under the plate. Now there is no metal plate touching the truck. Thanks for the tips guys.
