Rear Lift Shock
MTD
So I got a 2.5" rear spacer kit for my rear coils and I want to know what shock I should run in the rear? I blew out one or both of the rears the other day on the trail (overloaded and hit a deep hole) and want to replace the shocks at the same time that I put in the spacers. I am looking to do a 5100 lift in the front. I am looking to do 1-2 in of lift in the front and 2.5 in the rear to compensate for when I pull my boat. Any suggestions would be appreciated. Here Is what I have found:
Rear:
Rancho Suspension/Monroe RS5187
Rear Gas Charged Shocks (90-02 4Runner)
So I have been looking at this all day and the rancho's are a no go because they are not intended to be used with a lift. So I called toytech and go the part number for their ES9000's they carrie. They carry the 22.7 inch extended, and 14 inch compressed ones. Summit has ones that are 21.7 inch extended and 13.7 inch compressed ones. Now which ones should I get for a 2-1.5 inch daystar lift??
22.7 inchers:
http://www.summitracing.com/parts/exp-922510/overview/make/isuzu
21.7 inchers:
http://www.summitracing.com/parts/exp-921513/overview/make/toyota/model/4runner/year/2000
Are the stock rear shocks not long enough for a 2.5" rear lift? Out of curiosity...
I would say it's absolutely fine to run them as long as you don't do series off roading. But who on here gets a lift and not go off roading lol?
Yes but the ride will suck. I have OME 890 springs out back and ran the stock shocks for a few years because I ran out of money and people said it would be fine. The ride was garbage. Recently changed them to bilstein 5125s. 200 bucks or so from toytec. Pricey but worth it.
And I suggest staying far away from anything Rough Country.
I ended up pulling the trigger on the n2.0s even though their customer service is terrible. Ill post up how they are after they are installed
BillM777
