Rear lower shock bolt hole eating bolts.
mckennar
Previous owner liked to cross thread everything, so it's no surprise that when I popped the rear shocks off to do the lift a few months back, both lower shock bolts were cross threaded.
I cleaned out the passenger side threads and used a new bolt, that went fine.
The driver's side... didn't, but I was still able to get a bolt to catch torque it to spec.
Fast forward today. I disconnected the driver rear shock to replace it (Bilstein 5100 leaking already), and when the bolt came out, the threads were mangled.
I popped a new bolt in there and as I was torquing it, I felt that sickening decrease in resistance and then it began to spin freely. I backed it out and tried cleaning the threads inside the bolt hole, but now I can't even get a new bolt to catch on the threads. They all want to cross thread immediately.
These things aren't replaceable, right? Am I stuck drilling, tapping, and going with a larger diameter bolt? Anyone have the thread pitch handy? (none of my taps / chasers fit)
My best guess is that would be a M12-1.25
The factory lower shock bolt is short. Maybe you can tap the threads a little deeper and use a slightly longer bolt. Who knows, the threads might already go a good deal deeper than the original bolt needs.
There are appear to be 4 or 5 rows of threads within the hole that are untouched. I tried removing the lock washer between the bolt head and larger washer/cap thing to see if maybe I could access those but by the time the bolt made it down to them, it was already too mangled to catch.
I have a spare axle housing here but that's kind of the nuclear option at this point.
Looks like you should be able to cut out the insert and drill it out all the way to put a long 5 inch nut and bolt if you cannot get it to tap to the next larger size
If you can get a minimum of 4 threads of contact you'll be in good shape and the joint should hold the correct torque.
Man, guess I'm not the only one who had this issue when doing the rear suspension on my truck. I had to jack up the diff at just the right spot to make sure I could get that bolt in straight but was super surprised to find that the bolt was no more than an inch and a half long. Pretty bizarre that Toyota decided to go with such a short bolt to begin with
I'm experiencing the same exact thing. My rear driver side is stripped. How did you rectify this? Rethread it or drill through?
Sent from my SAMSUNG-SM-N920A using Tapatalk
Heli-coil would be the "proper" repair since it's an internal thread. There might not be sufficient wall thickness to drill oversize and tap to the next larger size. In a pinch you could probably find a bolt with the right size shoulder that you could cut off the hex head, tap in the shoulder and weld it together, then use a nut/washer to hold the shock on.
I replaced the entire axle with the one from my parts truck. Prior to that I'd tried tapping it with a stock sized/pitched tap and that didn't work. I couldn't get enough bite and it kept shredding factory bolts. I was able to get 40 ft lbs out of one that I'd coated in locktite, so I used that until I replaced the entire thing. Best of luck to you!
ear lower shock "bolt w/ washer" 91619-G1222 torque spec. 47lbs (not 74lbs) cost was arount $2
m12, 20mm length,1.0 thread pitch (if you find one at store).
OEM is not grade 8+, I've stripped one at 74lbs. and now keep an extra on hand.
Crookedcat
