Rear Mount Turbo Questions
I've also been casually interested in the RMT for my 4runner....I saved your diagrams and was going to look at/save the pdf list and found pdf-archive.com seems to be infected with malware. Would you mind just posting the list in this thread?
4. I am using all ebay parts (turbo, bov, wastegate, turbo timer, boost controller etc), I did loose on of the seals on my turbo last week, ordered a rebuild kit for $30 and its up and going again with no problems.
Here is a link to most of parts I purchased including price, and where I purchased them from... Turbo 4runner Mod list .pdf - PDF Archive
What kind of fitting end is needed for the scavenge pump, I believe it comes with a barbed adapter, but should I be able to unscrew this and get an AN to NPT adapter right off of my line into it? I think I might go 4an feed, and 6an drain.
I will try to post the list on here, if I cant get it to work out right you can always email me @ [email protected] and I could just send you the excel file too ;)
Matthew, let me try to snap a quick picture of my pump setup at lunch and I will post it.
Alright, I am assuming that I could just run these guys into the pump, and even out of the block(3/8 to 4an) as they go to NPT. JEGS Performance Products 103202, JEGS NPT Hose End Fittings | JEGS Performance Products
I also shot you an email so that you have it if you get that excel sheet. Thanks again.
Some of the items I picked up from local stores here and I forgot the prices of some of the items...
ITEM PRICE VENDOR
Emusa T3/T4 turbo .50 A/R .63 A/R $139.99 ebay
12V Scavenge Pump $79.99 ebay
T3 (5 Bolts) FLANGE 3" V Band Kit $55.99 ebay
Type RS BOV + 2.5" adapter pipe $40.98 ebay
Rev9 RS 44mm Wastegate w/5psi spring $109.90 ebay
Universal Manual Boost controller $10.79 ebay
Universal Apexi Turbo timer $18.98 ebay
6ft 2.5" Exhaust Piping $46.00 exhaust shop
2.5" 2 bolt exhaust flange/gasket $13.99 ebay
T3/T4 T04E T3 Turbo Flange $14.43 ebay
Turbo Drain line and Feed line kit $43.98 ebay
JDM Aluminum Catch Can $25.00 ebay
NGK-BKR7e spark plugs $16.74 pep boys
2.5" to 2" Walker Exhaust Reducer $6.99 pep boys
O2 bung $5.99 pep boys
Exhaust Hangers $10.74 ebay
90 deg. 2.5" to 2" reducing coupler $11.88 ebay
90 deg 2" to 2" coupler $8.99 ebay
45 deg 2" to 2" coupler (x2) $13.56 ebay
Straight 12" x 2" coupler hose $12.98 ebay
Straight 3" to 2" reducing coupler $7.88 ebay
10 x 2" Hose Clamps $19.99 ebay
4 x 2.5" Hose Clamps $10.08 ebay
2 x 3" Hose Clamps $4.99 ebay
5x 12V 4 pin Relay with pigtails $10.95 ebay
NPT to AN fitting (oil return to oil cap) $0.00
3/8 - 18NPT Fitting (oil feed) $0.00
Misc Bolts (exh/turbo flanges) $0.00
Boost Line $0.00
3" exhaust piping (post turbo) $0.00
Stainless Steel Braided Oil Line (10ft) $0.00
16 gauge(?) Wire $0.00
APSX D1 Wideband G1 LED AFR $130.67 Amazon
Bosch Style 2" Mechanical Boost Gauge $19.59 Pep Boys
Bosch Style 2" Mechanical Oil Pres Gauge $13.99 Pep Boys
Universal Dual Gauge Pod $14.99 Amazon
It would be a lot cheaper to run the whole system as 6an(3/8"), would I have any issues, or would I just have to put more oil in the system?
Also, should I stick with the original 2.5" exhaust into the turbo? Some of the pictures appear to run a larger diameter. I will run a 3" out the back, but I am just wondering about the other end. Also, anyone know if plumbing the whole oil line with 3/8" (6an) would be alright?
I used 2.5" exhaust in and out. I see no problem using 6an for all of it. Use an oil restrictor on the turbo.
I feel like there needs to be more discussion about what specific turbo to run. Boost is not the biggest consideration but how much airflow will be generated at a given pressure. How many CFM does the factory supercharger push at ~7psi? You should be looking for a turbo that will flow similar to this at ~0.5 pressure ratio from a compressor map. The amount of air flowed from a turbo out of a TDi golf versus a GT4088r at 7psi will be enormously different. Just my .02.
-Steve
ITEM PRICE VENDOR
Boost Line $0.00
And this is why I supercharged :confused:. There's something to be said about simplicity.
Seriously though, how do you keep that all straight?
-Steve
This is the same one 2 or 3 other people are using, with almost an identical set up, and running under 7psi. That's why I am using this turbo, because it is the exact one others are running. Thanks for the insight, I am thankful people are willing to share their knowledge with a clueless teenager like me.
Fair enough, I'm just wondering if they picked that particular turbo because it matched the factory SC setup or just because it was cheap...
I can't personally speak for them, but I know at least Yoterman and Clownmeat are professionals at what they do, so I'm sure there was a little more thought put into it than what I am doing. All I know is that if it works, it's fine by me.
No madder how pro they are or how much they researched.. Anyone running China knock off turbos didnt research enough.
I can do years of research, I am 100% well aware of the flaws of these turbos, but if I can't afford a name brand turbo, and want to do something like this, it is my decision, it doesn't mean I did not research enough. For my application, I BELIEVE this will be ok, it may blow, but it's all a learning experience, I can drop a $3000 turbo in, and I could still **** something up. It is all a matter of preference, price range, and abilities. It takes 10 seconds to find all of the negatives of an eBay turbo, but there are also thousands of people, including a few that ACTUALLY run them on 4Runners that have had success, and they last years. Thank you for your 2 cents but it does not really apply to me, I have researched HOURS on this, and talked to numerous people that have had success with this. I do not know your experience, or how much you have researched this, but maybe if you researched more, and really delved into this set up, then maybe you would see that if set up correctly, it can be a reliable set up.
seltzernator
