Rear O2 Rusted Off
RPS99SHO
Today I heard a new rattle, then a few miles later the exhaust tone got real loud. I knew exactly what it was, and a roadside visual inspection confirmed it; the rear (post-cat) O2 sensor and bung have rusted off the pipe. I'm guessing I need a new pipe and O2 sensor (duh). The sensor should be pretty easy, but I fear the pipe is not. And even if I do find a new one, I doubt the existing one will come off the cat nicely. They seem to be rust-fused together. Anyone else dealt with this?
I do need a working cat and sensor. MD does emissions testing every other year. And go figure I'm almost two years into ownership. Assuming I can get this pipe off the cat without cutting, anyone know where I can source a new one?
I vote for welding it where it's cracked if possible. They're not gonna look under the vehicle during an emissions inspection (I'm in MD too).
Help! Those who have purchased aftermarket cats. Which one do I get? These two from Eastern have different flanges for the upstream side.
It's Non-Cali. pre- 2001. 2000 was the last year for Federal one-cat systems.
Dammit I knew that (typo). And I know you know that since you always post the correct information in these threads (I searched after the fact). Thanks for the correction in any case!
I don't mean to be picky, but you never know who is looking through here for an answer to their problem, so I try to keep things accurate on stuff like that.
Had to come check out this post, as I just dealt with the same issue last night, except the nuts completely rusted away on mine, and the sensor was rattling in the pipe and the gasket was gone. Was driving me crazy trying to figure out what was rattling!!I ran the correct die over the stud threads, replaced the sensor with a new gasket and put new nuts on. Seems to be all good now.
H.Sikina
