Rear power window/ Power locks
Brian Keeler
Searched threads but didn't see the solution to my problems.
Have had the 2001 for a week (will post pic soon). Been trouble shooting things. First the rear window would only go down 1". Took apart and found where a bolt was loose and the part was interfering with window...great, easy fix. Put all back together and window works to go down with key fob. Works up and down everytime with key. But the power switch only works when it wants to. Took cover off the see if I pinched a wire, doesn't look like it. Switch seemed to always work when fooling with it when would only go down 1"
Power locks. With switch on door, all locks work. With key fob, first time lock usually locks all but if you hit unlock and lock again not all lock. Also not all unlock. Seems to be random with one doesn't work...
Thanks for any help!
You have to hit the unlock button on the fob twice to unlock all the doors. Hitting it once only unlocks the driver's door.
Yup, I am hitting twice. Correction...the inside lock and unlock button on the door is fickle too. Seems like the first time you hit unlock or lock all work. But after that it is random what works and what doesn't work....mind of its own:confused:
workingwheelswnc
