Rear shock mount relocate with stock wheel/tire
Upper rear shock mount failed, rusted through which caught me off guard because the rest of the frame is in great shape.
Would moving the shock mount outboard require a spacer if using the stock wheel / tire size set up and stock sized shocks?
Currently running 265/70r16s on factory aluminum wheels.
[MENTION=479699]BetterontheMtn[/MENTION] it's a good question. It likely depends on the outboard kit you get.
This might be your best option as it's designed around keeping the same shocks that fit factory location.
The longer hoop style ones are likely out of the question, since they are designed around running longer/bigger shocks, which are typically associated with larger lifts.
Good luck.
peacefulpiranha
