Rear spoiler removal
jharris2 said:
They make them out of metal now??? I thought they were wood only! :D
The 1X12 yellow pine trunk wings only come in the kits with the 50' roll of black garden edging for making your own ground effects...... ;):
p nut said:
You guys do know that the rear "spoiler" is not for looks only, but actually has a function. My last Jeep Grand Cherokee did not have the rear air diffuser, and the rear window was ALWAYS caked with grime, dirt, etc. Having the rear wing helps the rear window keep clear.
You would not believe how fast your rear window gets filthy without this gizmo---especially in winter after a snow storm.
:iagree:. I have the spoiler and on my way back from the Sierras this winter, I saw another 4th gen and his back window was much dirtier than mine. He was also using his rear wiper to keep it clear. I never used the rear the wiper before--for all I know, it's possible it doesn't work. :p
If you are not on a limited time constraint, order the vehicle you want with the options you want. You can special order almost any combination. Remember this is the vehicle you will be keeping for a long time (you hope), so unless you have to, don't settle for anything less that what you want.
I got the call that mine came in today. It is a fleet vehicle so I had no options. It doesn't have a roof rack or spoiler, it looks really naked. Is it possible to mount the OEM spoiler to a hatch that doesn't come with one? I see that the light on is on the hatch, but that could be disabled.
It'll be pretty hard to get the OEM spoiler. IIRC it's over $600 from the dealer for the OEM spoiler. Spoiler Depot has one that's similar to the 2003-04 spoilers without the hump. The biggest difference is the third brake light, the OEM has it on the front face, whereas the Spoiler Depot version is mounted on the underside.
Does that one function the same as the OEM as far as clearing the rear window?
That's really inexpensive! Maybe that will be my first mod?!:bash:
You got me there. I don't know.
If there's a spoiler or no spoiler thread with postings before 2005, it might be an indicator of the effectiveness of the non-humped spoiler. I can attest the humped spoiler does keep back window cleaner.
The rear clearing effect of the hump spoiler is most evident when your running on the highway in the rain. The water is actively pushed down by the airflow. I hardly have to use my rear wiper in the rain, no lie. I occasionally use the rear wiper just to make sure the damn thing still works since it is dormant most of the time. Aesthetically, the spoiler also adds beef to the rear too.
ok looks-wise i'm still not feeling the rear spoiler...
but the more and more i read what everyone has to say, i'm liking the functionality of it :D
Well, for what it's worth, it's your money and truck. If you want it a certain way then by all means go Burger King on it and buy it your way. You will have this vehicle for a while and like any major purchase you should be satisfied from day one. Now the HOWEVER part...
However, if you are still undecided I would go to the dealer and STARE at a runner with a spoiler and one without (assuming they even have one without). Staring at internet pictures don't do the real article justice after all. Go and touch the actual spoiler, bang on it, yank on it (before they possibly kick you off the lot). I have to say that the newer spoiler makes the rear end look more complete. It also has a LED array brake light. Furthermore, let's say you bought a spoiler-less runner and then decided later you do want one. You will have to look for one, a reputable and competent shop, and consequently disconnect the existing brake light on the hatch door. May be cheaper and easier just to get one from the get go. However, if your set on not having one, nothing wrong with that either. It's all about your happy factor that matters. :)
