Rear Sway Bar Diameter Q?
ScarfaceT4R
Hi!
I'm trying to locate the diameter of our 5th gen SR5 rear sway bar diameter so I can order new brackets (because I bent the crap out of my OEM one last night...) I'm pretty sure 4th Gen is 3/4" but I don't know if ours are the same? I can't find the answer anywhere!! Due to work situation of being locked up, I can't just go measure & I would like to order the parts ASAP. Here's what I'm thinking will fit:
Energy Suspension 9.5156 - Universal - Greaseable Sway Bar Bushings -19mm (0.74 inch). Energy Suspension ENE-9.5156G
Thanks!
As stated above, 19mm Go with the prothane 19mm bushings, they are a direct bolt in swap and they have grease fittings.
Interesting...I wonder why the Energy site says to go with the 19mm (0.74") when the specs say the sway bar is 0.787" @ almost 20mm?
Crap, I just ordered part # 9.5124 (20mm @ .78")
