Rear transfer case dead?
Supermoney
Transfer case dead?
Hello everybody.
I have a 2001 and have been diagnosing this 4WD issue for a while now, I have replaced all 4 sensors on the rear transfer case (2 on top, 2 on rear).
Now I have to test the rear actuator with 12v on pins 2 and 3 to see if I can get the actuator to move and into "4WD mode".
My question is, if this doesn't work am I basically out of luck and my rear transfer case assembly is bad? I know the part alone is over $1000+ and the labor is very intensive as well.
It would really suck to have to put that much money into my truck as I also just bought all my lift parts recently but don't really want to put the lift on before I am sure I can get my 4WD working.
Any help is greatly appreciated.
If it's a "j" shift case, just put a manual one in there, and run the front diff actuator to a switch.
Don't you mean, if it's a push button/push forward style, just put a manual "J style" one in?
In any case, swapping t-cases is NOT labor intensive, there are 8 bolts that hold the t-case to the trans, takes all of 10 minutes once you have the driveshaft off. I just swapped t-cases last week.
Rear TC? I thought the 3rd gen just has one transfer case in the front near the skid plate. Am I missing something?
Oh right, basically the dealer wants to swap the actuator INSIDE the t-case...for $$$$$.
So I can just find a working 2001-2002 tcase and swap it in?...
You are probably right, I am a IT guy that does wrenching in his part time and not 100% sure on our trucks setup lol.
Thanks.
You're thinking of the differential. And there are 2 of those.
Oh I see...
Does your 4Runner have full-time AWD? If not, I don't see why you couldn't just swap in the same style of T-case from any 3rd-gen 96-02. But if it is one with AWD then yes it will need to be from a 01 or 02.
Oh I see...
I am not sure what full-time AWD is on these trucks, I didn't know these trucks came AWD with no 2WD at all. Usually its always rear-wheel until we engage the "4WD" button the on TC shifter. Then its in 4-hi and we can drive it on the street, etc.
Is this what you mean for AWD or did these trucks come AWD all the time with no 2WD available?
No. I mean if it is a "j" style shift case.
He made it clearly obvious that he has a rear actuator on the back of the case. If it's a "j" style case, Which my Runner had, WITH the push button 4WD, just put a manual "j" shift case in there.
The reason I said that, is because I'm not 100% sure on the differences between the "forward" shift cases, and the "j" shift cases, though I know there are some, besides the actual shifting. Better to swap "j" shift for "j" shift, then to try and put a manual "j" shift into a "forward" shift, and find out that there's a problem and it won't work.
Seems to me like you have the push button/push forward shifter like I do on my 1997 Limited.
I'm not 100% sure but I think some of these 4Runners came with a t-case that was always in AWD but you could go down to 4wd low. Maybe someone could chime in here.
Anyway, I think any T-case from 96-02 with the push button style will work for you.
Ah ok I gotcha, just some misunderstanding here.
And yes I agree.
Assuming your signature is the vehicle you're talking about you have a 2001 so YES he has the multi-mode with AWD and not the J-shift. He needs to swap it with another 2001/2002 4Runner. Can be a SR5 or Limited, they are all the same for 2001 and 2002.
Yes, it is a 2001 SR5 Sport Edition...
Any idea on how much I can snag a confirmed working TC for?
[MENTION=76419]Doc2012[/MENTION]
It is indeed the ADD version with the MultiMode AWD non-j style.
Is the 01-02 TC swap the same process as the J-style one?
Yes, should be the same 8 bolts that bolt it to the trans. I believe they are 12mm heads, and you will need to remove the t-case mount to get to 2 of the bolts, the mount is held in by 4 14mm bolts.
