rear upper control arm bushings ?
3bears
Senior Member
am I looking up wrong. I find entire upper arms but not bushings. arm # 48710 35040
want to stay original toyota...when I did a search in this forum I saw threads saying not available and have to buy entire arm
still true ?
when I do other searches it takes me to the panhard rod
want to refresh my rear suspension,,,thats only parts I cant find..
.rear lowers no problem finding those...or panhard...and of course shocks and springs are no issue to find
thanks
I just replaced my rear upper control arm bushings.
I am not sure if Toyota makes a replacement bushing for these. The bushing encapsulates the entire circumference of the control arm on either side of it.
In fact, I had to cut the bushings before being able to press them out, so i have no idea how it would be possible to replace them with OEM pieces.
I used Whiteline Poly bushings for my replacements, Part# W63379
Rear Upper Control Arm Bushing Replacement - YouTube
still true ?
thanks
[MENTION=279370]WeakSauz[/MENTION] is correct. Toyota does not offer them on the parts diagram.
last time around when I did mine I used white lines both upper and lower.
W63379 - Trailing Arm - Upper Bushing
W83374 - Panhard Rod - Bushing Kit
W63378 - Trailing Arm - Lower Bushing
They are surprisingly expensive for what you get.
thanks guys
to be honest....not sure I want to go whiteline when stock lasted me 240k..and they are not worn out...just want to replace while doing a suspension refresh...so maybe 200 for both uppers...new toyota...is not that crazy and no press work...but I have a press so ?????? argg...i dont know...i just dont want to pull things apart again in a bunch of miles ...hate doing things twice.
The aftermarket upper arms are decent enough. Mevotech or Moog seem fine.
They are really easy to replace, 4 bolts and maybe 2 plastic clips.
If your not lifting lots or rock crawling....would think your money would be better spent elsewhere.
Tetanus 1 has a complete set of rock auto control arms uppers lowers in it. I went that route because it was quick and solved my bushing issues. The upper control arms are tubes and wider diameter then stock. The bottoms are very close to OEM thickness. :)
thadjay
