Rear upper control arms wont line up
brandon-4runner
Does anyone have a trick for getting the rear upper control arms lined up? I have a 1/4" to go. Everything is binding up and it won't allow me to get the bolt all the way through. Axle up doesn't work. Axle down doesn't work. I'm at a standstill. Put ome 906s in the rear. Do I need adjustable arms?
Is your panhard bar bolted up? You can try unbolting that to give yourself more side to side movement. Might need to lower the mounting for it.
Ambrose67
