Rear View Mirror Obstructing Forward View
RockyRider
After driving the 4runner for awhile I realise that at 6'1 I don't really fit. The proportions are optimized for smaller people. One of the freaking annoying things is that no matter where I place the rear view mirror it's always in my way. My main forward field of view is between the drivers pillar and the rear view mirror. I'm constantly having to slouch in my seat which is uncomfortable or bob my head around to see underneath the mirror.
Here is another driver that feels my pain.
2010 Prius Rearview Mirror Obstructs My View Even When Pushed All the Way Up | PriusChat
Are any of you dealing with the same problem? I'm nearly to the point where I want to remove the rear view mirror entirely. The large side mirrors provide plenty of rear and side visibility that almost makes the rear mirror not necessary.
...I should have purchased a Tundra.
is the mirror all the way up as far as it will go touching the headliner? every truck i have i move them as far up as i can
IMG_20140505_110711_zpsd4296f6c.jpg~original
IMG_20140509_180255_zps66ad6817.jpg~original
Why don't you remove it or fold it up flat (as possible)? When I take long trips, the back is usually so full I can't use my inside mirror, so I just use the outside mirrors. Same when I'm driving a box van. There's an inside mirror, but it can't see through the box. :jump:
As always, YMMV.
Daren
This guy is 6'8"..I thought about doing the washer thing since I'm 6'1" too
Easy:
Finally got a chance to look at my seat. I ended up solving my issue very easily. I took the front two seat bolts out, loosened the rears and found 6 washers. 3 on each side and then tightened everything down. This moved my seat a noticeable difference upward on my thighs and leaned it back some more. This also still left me with good amount of threads to still anchor the seat into the floor. I was even able to move the back of the seat forward once this was done. All in all, its minor but so far it seems to fix my height issue. I went from looking out the top of the windshield to looking more out the center, which is a big help on my neck.
If you didnt know any different you cant even tell.
20130420_144829_zps9a89b3a3.jpg~original
20130420_144845_zps9f985675.jpg~original
Advanced:
FINALLY got time to hit the shop and lower my seat. What a difference! I feel like im so much lower. I see out of the middle of the windshield, not the roof, i no longer hit my head/hair, can close the sunroof and NOT hit it. Im so happy i was able to do this and i took plenty of pics for everyone.
Seat removed
20130808_164123_zpseb2961af.jpg~original
Friend grinding the edges of the brackets
20130808_165259_zps4737f0a5.jpg~original
You can see our cuts on the lower bend here
20130808_165927_zpsc5bd38cd.jpg~original
Hit it with a hammer to flatten it out, can also see our second cuts on the outer most bend on the closer bracket. Farther bracket is flattened as well.
20130808_171203_zpse49ca8e5.jpg~original
Test fit to make sure thats enough
left is original, right is the one we cut and bent (huge difference)
20130808_171731_zps49545c67.jpg~original
Little welding to sturdy the brackets and make it right, also welded the top cuts after picture.
20130808_171325_zps045833fc.jpg~original
Bore out the mount holes a little and tape up the side panel to trim. Used washers on the seat bolts to cover the bigger bore.
20130808_174614_zpsba79c338.jpg~original
I taped and then cut the side panel with the dremel and a disk.
20130808_174607_zpsc164d6fd.jpg~original
Closer look at the bracket now
20130808_174638_zpsfc822b81.jpg~original
20130808_174641_zps977a0ddc.jpg~original
Installed, you can see where i cut a little too much off. I also sanded down the burs/edges from the dremel cut. The picture makes the edge looks a lot more noticeable.
20130808_175638_zps4e1d1a18.jpg~original
Thanks jfry008 and danronian for the excellent suggestions. I'm going to have to try both of those. :thumb3:
I was also contemplating the possibility somehow cutting the seat cushion lower within the seat. There is about an inch of extra head space that could be gained.
Jhunt
