Rear window problem
carrollcy
Hello,
I installed new battery and rear window will not go down/up automatically using inside button or key fob. I tried re-initialze process and driver side door is OKay but rear window is not doing what it ued to do, even when I push key fob it makes beep sound but window is not going down.
Thank you very much for your help in advance.
Cliff
Run the back window all the way down and up from the dash switch a few times. The sun roof too. It may take a try or 2 until the auto sequence works again.
Assuming you have a 2003-2009 model (4th Generation), see this thread for instructions on resetting things after you disconnect the battery.
Than you very much for your information. I have tried same as what it said from the thread but it didn't work plus I can't even roll up/down rear window using the key on the back door. Pleasde help.
Thank you.
Cliff
Thank you.
Cliff
Songtan Sally might help. j/k.... I'd say re-install the back window.
Is the window lockout button depressed? The window lockout also disables the rear window switch, not sure about the key though.
I checked the window lockout switch also. It is very strange, it is going up/down by the indoor switch. Any advice will be highly appreciated.
