Rear window Problem
The Wanderer
The rear window will go down with the remote and key, but not from the on dash switch. Checked fuses and they all seem to be good. Probably the switch? any one else come up with an idea? Is there a way to get to the back of the switch?
Any help would be appreciated
Did you double check your child lock? It's located on the drivers side door..... Make sure thats in the unlock position. Just a thought...
Bundles09
Read your reply and said OK haven't tried that. Put the key in the ignition and fired her up, the window lock was depressed and I pushed the button so it went into the up position. pushed the back window dashboard switch and PRESTO!!! I have to tell you I started laughing!!
Thanks !!!!!!
