rear window wont work
Porda
I just replaced my tail gate locking motor, but now my back window wont go up or down, and the rear wiper kicked the bucket as well. Anyone ever have this problem? or have any suggestions to fix?
If an electrical component fails, always check the fuse (or circuit breaker) first. Because you were doing other electrical work in the area, make sure you did not disconnect any electrical connectors to the window motor or rear wiper motor (or forgot to reconnect).
I cant find the rear window fuse in the panel, is it labeled under some other accessories circuit?
This happened to me and the solution was so simple it was overlooked by many...Make sure the windshield wiper is properly seated in its cradle. If it is not, the window will not go up or down. I hope it is this simple for you.
Interesting. I didn't know that.
Turns out thats exactly what the problem was, thanks!
