Rear wiper arm spring
superwhite14
Today I went to change my rear wiper blade and the spring was so corroded that it broke off. Does anyone have a part number for just the spring? I am hoping to avoid having to buy the whole assembly. Thanks in advance!
I can't answer your question, but even a complete OEM assembly isn't terribly expensive. Olathe Toyota has it for $63.45 (I searched for MY 2011 since I don't know what you drive). Might be nice to have a whole new one anyway.
Good luck removing the arm which is under the spoiler, I think the spoiler needs to be removed which does not look too difficult to do though.
^^^ This
I just did this last month on my 2012 for the first time. This wiper arm will be corroded to the spindle. if you live in a winter climate there is a good chance you will snap the bolt or plastic of the wiper arm. I got the bolt off easily which was a surprise but the arm was corroded in place. that arm is all plastic, so trying to pry it off the splines you will break it apart from the metal sleeve insert
I had to replace my wiper motor in the rear and bought the motor and the wiper arm. I tried to remove my old wiper arm from the old motor and the plastic broke and left the metal insert attached to the splines. removing the spoiler is easy, the 4 inside bolts of the hatch use a magnet but it really only took my 5 minutes to remove the spoiler
