Rear Wiper doesn't work...
H1_VLTG
:confused:
I noticed my rear Wiper, rear window heater strips, and Rear wiper fluid sprayer aren't working. I checked under the hood to see if a fuse is blown...but I didn't find a fuse for the rear. I assume either I over looked it or there must be another fuse block I didn't check. I haven't had time to check the owner's manual yet.
Any help would be greatly appreciated...Thanks
hit the button to make sure that your rear window is all the way up. i have had this happen to me before, even if the window is down an inperceptable amount, like 1/32 of an inch, all of these functions won't work.
H1_VLTG said:
I'll check during lunch time, Thanks Guys. :D
That's all my guess too. First just try to open/close the rear window all the way. Good chance that'll "fix" it right there.
That fixed it. I don't even remember openning the rear window, but apparnetly I must have.
Thank god it was an easy (cheap) fix.
This happened to me too, but I had to roll the window down then roll it back up. You'd think it would just tell you if your rear window is down
You may not have. At some point the battery may have been disconnected for replacement or maintenance reasons. When this happens, you need to re-initialize the sunroof, driver's door, and rear window by running it all the way open, then all the way closed. Doing it to the rear hatch will "reactivate" the rear door accessories. The door/sunroof is to reprogram the "auto" function.
I can’t seem to get the auto function to work on my rear window. I opened it all the way down and closed it up but still the auto down doesn’t kick in. Any suggestions on what I’m doing wrong?
