Recommend a come-a-long (cable winch puller)
e60ral
Banned
I need recommendations for a come-a-long (cable winch puller). I know of the Wyeth-Scott More Power Puller line but I'm trying to find something decent that is less expensive.
Also what capacity should I get, I drive a 5th gen. Think i need a 4 ton, 3 ton?
You can use a Hi-lift jack as a winch too, just something to think about. I've seen come alongs fail here for other members so I'm not sure I would trust them, but those also might have been cheap harbor freight ones.
Hi lift jacks are awful as winches, I've done it and have no interest in a hi lift
Sent from my P00A using Tapatalk
Coincidentally OutdoorX4 has an article on winching with a hi lift that shows a good size comparison. In addition to rigging being easier with a comealong, it's also smaller
Sent from my HTC6525LVW using Tapatalk
American Power Pull
American Power Pull makes a come along that is identical to the Wyeth-Scott for about half the price. As far as I can tell there is no difference between the two. The rating depends on the safety factor and as far as I could tell they have the same capacity. Capacity on either brand is halved if you don't use the pulley hook. I bought the American Power Pull as a much less expensive alternate to a steel bumper and winch or hidden winch mount and because we rarely use it here in So Cal.
American Power Pull
http://www.americanpowerpull.com/images/CablePullers/15002.jpg
Cable Puller
Contour Grip
Cast Frame, Ratchet Wheel, And Pawl For Added Strength
18 Feet of Extra Heavy Duty 5/16" Aircraft Cable
Zinc Plated Detachable Handle
Only 24 lbs
Drop Forged Safety Hooks
I have a MAASDAM POW'R-PULL Model 144SB-6 2 TON. I bought it in 2002 for not much money.
It works just fine for pulling a 4000 lb vehicle up a 3 foot rock waterfall. I haven't used it very many times over the last fifteen years but it works just fine.
American Power Pull
Cable Puller
Contour Grip
Only 24 lbs
have you used yours? any issues? the amazon reviews are... not good.
American Power Pull
Cable Puller
Contour Grip
Only 24 lbs
i have used my More Power Puller for 25+ years, it has done more recoveries than I can count. Well worth the $$$
Just to clarify, you are talking about the more power puller not the one they linked, right?
Here are examples for 4 and 6 ton dragging capacity, although these use synthetic rope:
https://www.wyeth-scott.com/models.asp
One would need to match the strength and diameter of the rope to the strengtj and rope-handling capacity of the tackle block.
okay, yeah that's just a regular come-a-long with synthetic rope instead of wire rope, your pull length is still limited to what you can fit on the drum
i thought you were talking about tirfor/griphoist style winch where you are only limited by your rope/wire length, the problem with those though is that anything with a decent rating costs a fortune.
Quality and Capacity comes with a price, gotta pay to play sometimes
MMJR_T4R
