Refinishing your center console's 'upper trim panel'
rigtec
Hi team,
I received a pm regarding a recent thread that I posted on called: Center console swap - Toyota 4Runner Forum - Largest 4Runner Forum. In that post, I mentioned that I had screwed up (Biblical scale) a project that I was working on that involved drilling two small holes in the center console upper trim panel. After I did it, I was unable to locate a replacement panel to get it resolved so I had to fix that one. The person that sent the pm was inquiring as to the paint I used to finish the job. He alluded to the fact that these upper trim panels scratch sooo very easily, to which I totally agree. So to those of you who will need to re-finish the "Center console upper trim panel", Here's what I did...
First, I removed the original panel so that I could ruin it, using a trim panel removal tool; cost was about $5 dollars for a two piece set:
Just insert anywhere, pry gently all the way around the edges (you'll here/feel the clips unlatching) and lift slightly as you go. There are two short electrical harnesses beneath this panel; 1 for seat heater dials/rear window control switch, and 1 for the transfer case control knob (if applicable), so once it's unclipped you'll need to reach under it and unlatch the connectors. To release the primary connector's latch, use your thump to depress this button (below) and pull (lower photo):
Now the second one, the T/C knob. Just do the same thing as before, depress the release latch and pull. Now you're free to remove the panel for dismantling. With the bottom side up, you'll see the small clips holding the switches and rear cupholder in place, just use your thumb or small screwdriver to unlatch each one. Now the front cupholder is held in by several philips head screws. Remove them all and the black insert will come out!
When I drilled the holes, even though I used a piece of pvc electrical tape to mark the proper size hole cutting edge, I allowed the bit to begin beveling for the next size hole; which happens before the uni-bit begins cutting :redface: totally heartbroken... "should have drilled the holes from the bottom".
Now just to show the mess I made BEFORE the repair, here it is:
Before
"What a mess"
Because I now had two 'curiously freakish' looking holes in my console, I had to find a way to fill them. Using a two part epoxy by "JB Weld, I simply mixed a small portion on a pallet :artist: filled the holes by spreading it w/ a putty knife and let it dry overnight.
Then I filed it down flat the next morning and sanded it until smooth as glass! But this thread isn't about filling holes, it's about the finish, so once that was done, I wiped the 'now repaired' trim panel clean using a wet paper towel, dried it off and took it into a dust free environment for several coats of a premium trim panel paint. Here's what I used:
The color is called "Gun metal met" (Met for metallic). It's not an exact match, but I tried (bought) several other paints before choosing this one and this one's so close it's hard to tell. I actually like this better than the original because it's a bit richer/deeper to the eye. But the important thing is... it will match and only you will detect the difference! Take a look:
After
I used three coats of paint on this application, spacing the coats about 20 to 30 minutes apart. Just be careful not hold the can too close to the surface of the panel. The temptation will be to use one very heavy coat to save time, but trust me, the finish won't be nearly as smooth as using three or four ultra thin coats... feels like satin and looks just as good as the factory finish!
So now you're ready to install your trim panel back into the console. There's no real need to show you how to put it back in your truck, most of you guys (and gals) are perfectly capable... but if you do have trouble you can always pm me for help (P'sst!... and I won't tell anybody that you did!) lol! "And don't forget to reconnect those two wiring harnesses before you close it up! Happy motoring team! :car:
rigtec, cheers
Hey rigtec,
You know what they say........the difference between amateurs and professionals is how they cover their F'ups............:bolt:
Takes a big person to admit when they've made a mistake, kudos to you.
Nice write-up buddy! Pictures???????
Hey rigtec,
Hahahaha! "Neva has dare been a mo bedda sayin' den dis" man! :pimp:
Well, when you've had as much practice F'ing-up stuff as I have...
But thanks for the compliment bro! lol!
PS:"...and thanks for alerting me to the missing pics, good lookin out"!
Greg, (rig)
good job and nice write up.... now do you know also how to remove the silver plastic trim on the steering wheel? wanna paint or wrap that part as well..tnx
Hi dzuwel,
No, I don't; just looked at a picture of one on google but it only showed the 'face view'. Why not take a picture of the underside (bottom) of it so we can see if there are seams or if it's one piece. If there aren't any seams, maybe you could "mask" the s*#t out of it and get a way with doing it attached.
PS: On second thought... If anyone knows off-hand, [MENTION=65614]Antman[/MENTION] would. Maybe he'll chime in on this one. Regards
I have had those pieces off the steering wheel, lol.
IIRC, you need to remove the airbag (not unplug but just remove the screws and hold it out of the way) to get to the screws for the silver trim.
The airbag comes off really easy- pop the 2 plastic covers off behind the wheel. Loosen the torx bolts inside- the bolts are trapped and won't come completely out- and pull the airbag.
Very easy takes you 2 minutes.
PS- You may want to disconnect the battery first before you hold that bomb in your hand.:doh:
"...The airbag comes off really easy- pop the 2 plastic covers off behind the wheel. Loosen the torx bolts inside- the bolts are trapped and won't come completely out- and pull the airbag. Very easy takes you 2 minutes."
Hey [MENTION=94212]dzuwel[/MENTION],
Hear that... it can be done if your interested. Thanks antman!
Not me! That bomb can stay right where it is! :painkiller:
Thanks again Jeff
For anyone wondering where the pictures are like I was, you will need to disable your ad block extension in order to view them.
Thanks for taking the time to document this [MENTION=83083]rigtec[/MENTION]
tnx [MENTION=65614]Antman[/MENTION] and [MENTION=83083]rigtec[/MENTION] .......... haha nevermind messing with the bomb as rigtec says..the bomb can stay where it is :biggrin1:
anyways tnx 4 d lift gentlemen:clap2:
Hi [MENTION=110495]Carthage[/MENTION],
Regarding pictures...
I've made several mistakes posting them. At one point, I didn't understand that if you upload your pics to this website, you cannot delete them once you're done posting your subject material or they will disappear (ask me how I know); ruined several large picture threads before. I mean filling up many pages where you'd run out of room to write, then put... "continued below" then starting a new post below that one. Then to fix that, you have to figure out which picture goes where (cuz 20 or 25 pix are just gone), relative to what's being said in that spot. It's devastating!
This time, I loaded these photos into an album (here on site) that was dormant, set for "private viewing only", so once I found out you couldn't see them, I just changed it to "public viewing"; a bit embarrassing but it could have been worse. Guess I'm gonna have to start using "Photo bucket" because I'm running out of room here! cheers
Greg, (rig)
Now that the pictures show, you are a professional :photo:, great job man!
Cool!
Any chance you or anyone else that has used this particular Dupli-Color metallic silver paint also has a Scosche Dash Kit (for aftermarket radios)? If so, does the Dupli-Color paint match the factory silver color better than the Scosche kit does? The Scosche dash kit's finish is nowhere near as "Metallic" (sparkly) as my factory silver parts are ('13 SR5).
I wanted to re-paint my Scosche dash kit anyway (2012 thread) (has a few blemishes from shipping), but if this Dupli-Color paint is actually a better color match, it would REALLY motivate me to get of my butt and tackle it (2 years after I made that initial thread!) :)
Thanks! :cool:
Hey gang,
I had this on my mind when I posted this thread so I thought... what better ^X than now to mention this. Just in case some of you were wondering what that mysterious blank-off insert is for that was in your glovebox the day you drove your new 4Runner home from the dealership.
It allows you to move the shift lever out of park when the engine is not running and w/o stepping on the brake pedal; 'for servicing'. You just remove the insert with a small screwdriver (pictured above) and press down on the release tab just inside of the access port. Now just hold it down and shift, that's it! This idea sure makes things a bit easier when you're working on a vehicle electrical system w/the power cut, but you need to move the shift lever out of the way to remove a section of dash "without turning the key, or starting the engine"... "Way to go Toyota!" :thumb3:
rig cheers
<snip>
<snip>
rigtec, cheers
Took a chance and ordered the DupliColor Gunmetal Metallic paint (BGM0536) and a new Scosche Dash Kit so I can try to get it perfectly painted w/o yanking out my Alpine radio in the meanwhile. Will post pics once I get around to re-painting and swapping it out.
Thanks for posting the paint info, rigtec! :cool:
Hi Randyman,
Always glad to see our forum members getting inspired to implement someone else's "break-through", and possibly take that to a whole n'other level! I've never heard of 'Scosche' dash kits, but... live & learn! That's what I mean about this forum's power to inspire; 'Hey... just got a great idea for another write-up thread'... "got Scosche?" lol!
Have fun!
Thank you rigtec for this thread, I followed your instructions for painting the console and I am extremely happy with the results!:party:
alexaturner
