Relay issue with windows?
shamanrawb
Hey guys. My 2015 SR5 drivers door will roll down its own window, but will not roll the others, or unlock/lock doors. Also, rear window roll down and wipers won’t work, but can roll down with key in door. Also remote works with door locks from key.
This sounds like a fuse, but which one?
Also the automatic function doesn’t work on th driver window. All of this happened on the freeway about 10 minutes ago, which is why I’m thinking fuse/relay
Thanks in advance.
Thoughts?
I had a similar window issue that was resolved by rolling down and up each passenger window 3 times and then 3 times with the drivers window. I guess it resets something. Don’t know about your other issues. Did you recently run your battery down and have to jump it?
Jhunt
