Relay to fog lights
c0mmon
So im hooking up a 5 wire fuse (with the middle one capped)
and I just realize the reason it isn't working is because the switch part is not hooked up correct.
So to follow this you would hook up the relay to the switch and where would you tie in the voltage from the dashboard?
I'm not sure where you're stuck, but it helps to think of power flowing from 30 to 87, only to be interrupted by 86. Wiring your fog switch into a switched outlet on the fusebox allows the fogs to automatically be turned off when the car isn't turned on. Perhaps rephrase your question?
Runvod
