Removable fridge slide with 3rd row
Sounds like a solid plan. Check out [MENTION=91899]Jhalko[/MENTION] build here....Post #78 and 105 for more ideas. When I built mine I used what he was doing and [MENTION=107460]Magnetic4R[/MENTION] build and did what worked for me. It definitely takes some trial and error but having a custom system that works for you is worth it in the end.
Jhalko's 2011 Limited build/travel thread
:cheers:
This was really helpful! Thanks.
I ended up taking out half of the 3rd row out and put in an ARB roller floor. It works great and I don’t have to keep bolting and unbolting a setup. 1 3rd row seat is good enough for us.
I documented the process in my build thread. For some reason I’m not able to upload photos from my iPhone right now.
Good luck!
:cheers:
So funny this came up, I’m thinking about going to my third version. I want to build a box that will Allow more compartmentalization of things. I don’t sleep in the truck hardly at all anymore. I’m used to my RTT and it’s so fast to setup and take down plus I want to utilize the space above the fridge. I’ve been thinking up designs currently. Version two has been awesome for me though, solid, pretty cheap and is only in for the summer.
I have a molle surround I am going to use. One of the local shops built it. Trying to attach picture from my phone, well see if it works. Its molle panels on the side and a hard top to put stuff on.
I made a custom setup having a fridge slide with tilt, small slide out table and drawer with fold out table lid. I am using the two factory tie downs on passenger side and the LATCH anchor point on the back of the 2nd row passenger seat. All can be removed to use the 3rd row.
Do you have photos anywhere???
I used a single piece of ½” square steel tubing to slide through the 2 attachment points in the floor. The tubing also slides through 2 pieces of ¾” square tubing attached to the slide assembly. This holds the slide assembly in place. I also have a turnbuckle at the rear that engages the LATCH on back of seat. It sits on the drivers side and still allows me to use the passenger side 3rd row seat without removing it. Not as sturdy as installs without 3rd row, but so far no issues with the assembly moving when sliding out the fridge, but only used handful of times. And the fridge is Dometic CFX 35w.
Thanks for the info, although the pictures didnt seem to work and I cant track them down in the photo album section.......
I’m making something similar seeing as I sometimes need access to the entire third row. A removable fridge slide is a must for me.
Which fridge tilt slide are you using?
Wife is out of town so got a lot of work done this week. Going to get something at lowes to just go through the rear tie downs to lock it in place but its pretty tight. Picking up fridge tomorrow.
Pics not uploading for some reason. Sorry. Will keep trying.
johnnya
