remove cargo divider
ciaz
Anyone know how to remove the cargo divider?
I'll be doing a major overhaul on that puppy right after Christmas.....so if you can patient I'll documemt it.
Looks like there are nuts and washers attached to bolts on the underside of the sliding tray. A metal strip seems to be attached to the backside. Maybe this is how it is removed?
Hi Ciaz, why do you want to remove? I was actually thinking about adding this feature aftermarket to prevent small items from falling into the gap when I pull the slide out. Does this not work as it seems? Thanks, Nick
I will also be looking into removing this divider. I often haul items that need to be somewhat flat in the back of the vehicle. I moved a bureau the other day and it was a pain having it balance on the divider. Hopefully it is not too hard to remove as like it for everyday use.
Looking forward to seeing somebody pulling this thing off. It is nice, but its going to suck when I try to sleep back there!
It's very easy to remove - just four 11mm nuts and springwashers. I didn't even need a wrench cuz the nuts were only finger tight against the washers. A five minute job.
Personally, I dig my divider. A small toolbox and my ARB recovery bag with my pull straps & jumper cables fit snugly in front of it.
Keeps all my trail essentials from sliding around, especially offroad.
<a href="http://s748.photobucket.com/albums/xx122/lnordmann/?action=view&current=DSC00171.jpg" target="_blank"><img src="http://i748.photobucket.com/albums/xx122/lnordmann/DSC00171.jpg" border="0" alt="Photobucket"></a>
Thanks for the info, ckon. For those of us planning on taking this beast to the outdoors, it is a nice feature having that bed flat. Why set up a tent if you don't have to? For me, that would have to be the selling feature, aside from the excellent 4x4'ing capability. Otherwise, I'd go with a used 3rd gen.
Actually the back of the 4runner Limited is way short to sleep in if you are 6 foot or taller. Even going at a full angle it is really tight, and if you have much of anything else at all back there it is a miserable night. I continue to be surprised at how much less room it has back there than the Highlander, which is a shorter vehicle overall. If only they had made the seats in the Limited so they did not have to flip up to fold down it would have been much better - you lose 6-8 inches that way. The Limited is not a great vehicle to sleep in...
I agree, the Trail was tighter than expected, but I'm only 5'10, so diagonal seemed long enough. Plus, that was at full extension. If you lay on your side, it's plenty big. I tried it at the dealership. However, if you are 6ft +, then it would not be comfortable.
8 years later...
I know this is 8 years after the fact, but this is exactly the type of information I was looking for. I'm looking at a few 2012/3 Trail models, and I was wondering if that divider could be removed easily for a totally flat cargo space for sleeping...looks like it can! But what's underneath?
I honestly didn't know that was a thing. My 2012 TE that I bought secondhand didn't come with it, so I couldn't even figure out what everyone was talking about. Had to do a little searching to find most people remove it anyways.
