This is a curiosity question. I heard of some people removing a KDSS from a TRD Pro. I was told that if you’re a hard core off raoder your better off without it. What are the pros and cons of the KDSS?
Ok so KDSS allows for better handling and rides on rough dirt roads and dry river beds for example but limits rock crawling capabilities because it limits wheel travel. Removal allows more extreme rock crawling but sacrifices a smoother ride a bit and reduced cornering on roads. Did I get that right?
Oh ffs
Not really!
KDSS improves greatly handling on an otherwise stock vehicle, but the price you pay is comfort above 12 mph over choppy terrain. As others said, it is a monster sway bar that disengages at low speeds.
So the other benefit is in rock crawling a stock vehicle where you get extra wheel travel. This is a very real benefit but because most folks here lift for the looks or because they think they need a lift for a moderate trail, they don't appreciate the difference that a little bit of extra travel makes in off-camber and/or low traction situations.
The problem off-pavement is that while non-KDSS stock non-Pro 4R has mediocre to poor handling at speeds and also bottoming out problems, KDSS only addresses the former problem and at the a substantial price premium. By contrast, a decent aftermarket setup can solve both issues for less money (as mine).
So, it will depend on setup and use.
it limits travel at speeds above 12mph, that is what was said
Thanks for some of the good info. Much appreciated. The previous owner of my 4Runner removed the KDSS. The vehicle drives fine as it is but can still handle corners pretty well. I was trying to decide if it was worth putting the KDSS back in or go with a aftermarket shock like King shocks. Still exploring options.
Wolfman’s Brother;3510907 said:Mortal Kombat for Sega Genesis is the best video game ever.
This thread is for lunchroom conversation right?
If you still have a TRD Pro like your post suggests (and past posts suggest) your car never had KDSS, nor was it ever an option on TRD Pros. If you have a Pro and someone told you it used to have KDSS they lied to you.
t. it's essentially equivalent to a swaybar disconnect.
