Removing back plastics?
Bumbo
Does anyone know of any good threads that have some information about removing the back plastics on both sides of the rear compartment?
I want to run some wires for power, radio, antenna, rear lighting...
I got the fronts figured out pretty well but I must be missing something in the back. Not really seeing it. I am only worried about the lower plastic side panels.
Check out a section of this body lift thread that tells how to access the rear body mount bolts. This should get you closer, basically remove rear tread plate screws, remove bolts holding down tie-downs, remove clips that are the star shaped hooks on the walls (tricky hidden one there) and the side panels can start to be peeled back. Work your way forward from there.
Body lift install instructions
It's a serious pain in the butt because the panel is also screwed in below the carpet (which I just sawed off after the first time). There is a detailed write up if you search for amp and sub installs.
Jhunt
