Removing center console (not just the easy stuff)
krogers
I'm trying to remove the center console of my 07. Search brings up a dozen guides for removing the trivial parts that simply pry up around the shifter. I want to remove what is left after that - the giant piece that goes back to the passenger space which contains the large storage box and rear vents.
Four 10mm bolts to remove were obvious: 2 that attach the front to the dash area and 2 by the shifter. After taking them out I can lift the piece a bit up and down at the front. However, there's something about a foot forward from the back end that is holding the thing in place from full removal.
Half an hour of pushing, prodding and such hasn't given me a clue what to do. Pointers would be helpful.
There are 2 in the center console probably hidden underneath all of your junk in there.
Heh, I had removed everything from the storage box down to the carpet piece. But after your reply, I pulled on that, and sure enough, there are the bolts under the carpet. The console comes out now.
THANK YOU!
