Removing exterior door handles
bolts221
Does anyone know how to remove the exterior door handles on a 4th gen 4Runner?
I got the interior door panel off and unscrewed one bolt that attaches the handle, but can't seem to figure out how to remove the rest of the handle.
I am also curious on how this is done, I'd like to change my handles to chrome if possible, what is it that you're trying to do?
Mine is Natural White, or that's what they call it. It bright as light though I like it. Just got it yesterday.
2005 Sport V6, what the hell does color keyed mean?
Color keyed door handles are the same color as the rest of your car. I have chrome door handles on my Galactic grey 4Runner, so I'm trying to change to colored ones.
Have you checked how much it will cost you to buy the chrome ones?
MaliciousClout, I finally got around to ordering my color-keyed parts and am gettin ready to remove my chrome accessories in the next week or two. Are you interested in purchasing my chrome parts? I'd be willing to sell them to you for a reasonable price. Let me know if you want to try and work something out.
I've got chrome, but would like to have white. I would be willing to do an even swap if the 05's and my 07 are a match.
Replaced the grille, garnish and door handles today. Took a total of about 3 hours.
The thread K.C. posted on removing door handles for the Tacoma was extremely helpful. The only deviation for the 4Runner is removing the rear door handles. When you reach step 11, follow these directions instead:
11a) Reach into the door, pull the latch mechanism toward the inside of the door.
11b) There is a small hole that is covered by a circular piece of white/clear tape. Reach inside the door and punch the piece of tape out with your finger. This allows access to the Torx fastener that retains that back door handle "cap".
12) Resume with step 12 at: http://www.toyotanation.com/forum/t107022.html
door handles se hood grill
Bolts221, do you still have the stainless door handles and other garnish trim pieces ? I'm interested in replacing the colored items on my 4runner with the stainless parts from a sport edition also interested in swapping for a sport edition hood , mine is nautical blue metallic 2004 Limited
So my exterior rear door handle fell off the other day in my hand....... Didn't know I was such a beast :) Anywho, seems like a simple fix, I believe the bolt for the 'cap' was rattled loose. I removed the door panel and punctured the round white sticker that covers the hole which is in line with said bolt. Problem. The lock assay and actuator is blocking access to the bolt that I am after. What now?!
Door handle removal
A video showing how to do this would be so helpful!
Did you ever get a video or figure out how to remove these handles ? The front seems like you can do it without removing the panel but what about the rear handles ?
Door Handle Removal
I removed all 4 door handles on my 2003 Gen 4 today. I wanted to paint them with black epoxy paint. I was not able to get the toyotanation link to work. The front door handles have already been covered.
To remove the rear door handles, you only need a Phillips head, a flat head screw driver and a T20 Torx bit. It only took me 5 minutes each door. Remove the arm rest by pulling up on it. Use the flat head to pry out on the cover where the interior door handle is. I pried by inserting the screw driver between the handle arm and the cover and it popped out without breaking. Remove the 2 Phillips head screws you have exposed and pull out on the front lower part of the door skin. Pop it off and lift up to remove it from the door. I unplugged the light and let it hang by the latch cables. Remove the plug to the door latch/lock actuator. Remove the 3 screws holding the door catch at the top back of the door. Remove the small piece of white tape on the inside of the door and slide the catch assembly down and inch or 2 to expose the T20 screw that holds the stationary door handle on. The screw should stay in place. I left mine so it would not drop into the door. Use the flat head screw driver between the stationary piece and the outer door handle. Pry toward the back of the truck and it should pop out. Pull slightly out on the door handle and it will slide out toward the rear of the truck. It really only takes 5 minutes.
Here is a picture of the screw location. Once you pull off the little round piece of white tape, you can see the screw inside. It stays in place, so you should not have to worry about it dropping into the door. It was a T20 Torx head.
freddygino
