Removing Rear Passenger Side Door Panel
KG04SR5
So my 8yr old brings it to my attention that there was something wrong with the window switch where he was sitting. (I am sure he had nothing to do with it right??).. Long story short.. the window button has been pushed down inside the door.. It still works fine but is no longer in its usual spot. Anyone else had this problem? Easy fix I am thinking.. remove the door panel.. put it back in place and I am good to go right? I have seen pics / instrucitons of the front door panels being removed. Any suprises I should be aware of with the rear door panels? I am sure there are a few screws.. where are they? Thanks in advance for any help.
There are only 2 screws, one behind the hard plastic cover where the actual door handle is and then another under the arm rest, you must lightly pull upwards on the arm rest to remove the screw behind, once those are gone simply start to pry at the bottom and work your way up, the rear door panel is a lot easier to remove than the front
As usual...this forum comes through with the goods. The information and all the people involved with T4R.org are priceless. Thanks again.
MaximussK
