Removing the interior rear hatch cover. ...Antman
It's pretty simple... pop the tab off covering 10mm bolt at pull down rope. Then, use a pry tool or butter knife to pop out lights & detach clips. You will come from the driver side in both lights. Now, just pull the plastic away from liftgate starting at bottom. When all clips are released just slide the plastic up towards tip of window and it will come right out.
Sent from my SM-G935V using Tapatalk
Thank You.
Laredotx
