Removing XREAS and looking for lift options
06SPRTRUNNER
Hey guys, im a 2006 T4R sport edition and im looking to remove the xreas and replace with a lift. please post pics and what you have and your recommendations?
I have been looking at the OME lift with the nitrocharger shocks?
Hopefully i win the race against berettashot117!!
"Search Bar"
J/k above all the normal posts in the sticky sections, is a Lift/Tires post, check that out, more than you wanna know!!
Bilstein 5100's with FJ springs. I ditched my X-REAS for that and I'm very happy!
There's no way for us to provide a good recommendation without knowing how you plan to use your 4runner and how much lift your wanting. Also wouldn't hurt to post a budget.
As mentioned, read the suspension faq sticky and look through the lift pic thread that's also a sticky, should be a good start.
im looking for 3 inch lift. i do use my 4runner onroad quite a bit but do spend a fair amount of time in the dirt and in the mountain. i do tow quite frequently so i want something that will stand up to extra weight in the rear.
my budget is around 1500
Do you have any plans to add additional weight, such as front or rear bumpers? Have you decided what size tires you plan to run?
I have a couple different suggestions. They are ordered from cheapest to most expensive and what I'd consider good to best (this is subjective).
1). Bilstein 5100 shocks all around, OME 884/885 front coils (884 for v6, 885 for v8), a 1/4" top plate spacer for a full 3" of lift, and Toytec Superflex coils for the rear.
2). Toytec Ultimate Lift
3). Radflo or Icon coilover kit
Option 1 is good, it just doesn't offer the ability to adjust down the road. It's the cheapest, so you'd have money left for things like UCA's, extended links, extended brake lines, or skid plates.
Option 2 is slightly better because the fronts offer more adjustment options. It still is based off the Bilstein 5100 shocks, so not a huge step above option 1. With this you'd have enough left to buy UCA's and stay around $1500.
Option 3 is a step above option 2 because it uses better quality shocks. The Radflo or Icon kit includes rebuildable/revalveable shocks. If you order directly from Radflo, you can request the "Overland Warehouse" spec kit. This kit was fine tuned for our 4runners. Other kits are designed for the FJ Cruiser but work on the 4runner. This will push your budget and leave no extra money.
It's totally up to you. If you want to get just the lift and plan to add the other stuff later, then option 3 is probably the best. If you want to spend $1500 now and be done with it, options 1 or 2 would be my choice. All will have good on ride ride quality and do great off road.
A final note on towing. I would recommend air bags in the rear to support the added weight. You can get stiffer coils, but then it would be too stiff when not towing. By using the air bags you can have the support when needed and have a smoother ride when not towing. Either Airlift or Firestone kits would do well.
Thanks man!! i might either going to go with option 2 or 3. i have heard really good things about radflo and ill probably give them a call this week.
Thanks guys for all your help.
