Repainting/Rustproofing undercarriage
So i got bored today and randomly decided to do this. It turned out pretty good but, i only got done with this much for today. P.S. it had 5 years worth of Minnesota/Illinois's winter rust
looks good. I get the air line to spray off dirt/dust and the paint, but whats up with the heat gun?
oh ok lol, that makes a lot more sense. I need to do this to mine. what did you use to coat it with?
I sprayed the bottom of mine with rust converter which actually turned out pretty good considering I didn't make any attempt to wire brush the extra rust off. I plan on hitting it with more rust converter and then the 2000 degree high heat Rustoleum stuff so I can just spray the crap out of everything down there without worrying about it burning off, haha
the only thing i was worries about was the diff getting hot but it doesn't seem to as i can still touch it after a long drive
Do yourself a favor and buy a quart of POR 15 instead. It is permanent protection. I think you will find that what you are doing will not last more than 1 winter. I did mine last year and it still looks great. I do need to go over it again because I can see areas I missed now.
Thanks for the advice Gatafly i was planning on using that stuff but just randomly decides to do this i will defiantly use that stuff next time
Best stuff ever. Got me 3 extra years out of rusty ford oil pan.
Straight forward too.
Wirebrush off scale
Spray on there converter
Apply Por15
DONE....
