Replace pads or Tundra Upgrade?
Wow Mason, I guess you do need brakes bad!
Let me know what you decide to do, and/or if you need help.
Follow BFAD's link and you should be good to go.
The reason I asked AZ4FNER about the brake pads is that mess of goop between the piston and the back of the pad is the result of using the wrong type of lube (probably wasn't for a caliper); it heated up and became like tar. Plus too much was used also.
The Tundra brake upgrade is the best upgrade I have done on my 4runner, even better than adding the OEM locker.
I didn't take a picture of the new tundra rotors but here is a pic of the T4r rotor next to my old Lexus is300 rotor. The is300 weighs 3500lbs and the T4r weighs 4000lbs. I don't understand why a truck meant to trailer boats and other heavy items has such thin rotors.
ry%3D315
Left is300. Right T4r
So leaning towards the 231mm upgrade over the 199mm. Just a little apprehensive of possibly having to grind the rims or calipers down to fit. My 6 spoke stock rims are on the 'fit list' but some say they still need to grind them down? Is the 231mm really worth the effort over the 199mm? Going around in circles here! lol :)
Thinking of buying everything at O'Reillys unless someone can tell me a better place to buy for price or quality.
Thanks for all the help guys.
Mason
Mason
If you plan on just keeping your wheels then I would go with 199mm. Hey look at it this way, no matter which one you go with will be better than the stock 4R brakes :thumb3:
This is the way I'm leaning right now. Just trying to source the best parts for the job now. I have O'rillys, Autozone, Pepboys and Napa around here. Still keeping the 231mm in there though but think the 199mm will win out since I don't have to grind critical parts of the brakes/ rims.
Mason
Others will have other opinions or sources, but this is what I used:
Calipers: Advance Auto Parts, Buy Fenco Disc Brake Caliper, Front Left SLC9689 at Advance Auto Parts (left) and Buy Fenco Disc Brake Caliper, Front Right SLC9688 at Advance Auto Parts (right)
Rotors: Amazon.com, Brembo 25534 (x2)
Pads: Amazon.com, Akebono ACT812 (1 set)
I just sourced parts that would fit a 2001 Tundra.
Total cost ~$300 (not including the $100 core charge you pay up front for the calipers but that you get back when you return the old ones)
good info, thanks!
If you enter "P20" in the coupon box you get 20% off up to $50. Ive gotten all the parts down to $250 out the door from Advance. If you max out the discount code, split up the order so you can get a full 20% off the entire order.
