Replaced Knock Sensors. Now no Start Situation
Rudedawwg
Like the title says I replaced the knock sensors with two oem fenso ones. I put everything back together and now the car won't start. It's an 02 3.4v6. I'm pretty sure I put everything back together correctly. Any ideas?
I sprayed brake fluid in the throttle body and that didn't seem to help so I don't think it's a fuel issue.
The car ran beautifully before
it's been hqppening quiet a bit lately. Is it cranking? Double check everything could be something simple check all vacuum lines coolant lines crankshaft, camshaft connectors, ground wires, battery terminals' igniter wires etc could be something simple.
here are a few threads
http://www.toyota-4runner.org/3rd-g...ors-valve-cover-gaskets-truck-wont-start.html
http://www.toyota-4runner.org/3rd-gen-t4rs/255242-i-hate-ask-but-no-start-after-knock-sensors.html
http://www.toyota-4runner.org/3rd-gen-t4rs/259779-help-knock-sensor-r-r-now-wont-start.html
Thanks so much for replying. Those links really did help. Ended up pulling my spark plugs and sure enough they were all wet so I let the cylinders dry out and I put brand new spark plugs in.... Then it started right up!
TireSizeDB
