Replacement Bolt sizes for suspension? 4th gen
Elan750
Does anyone have any info on the suspension bolts? I can't seem to find the rear lower shock bolt on the parts diagrams, i swear its missing!
I think it may be: 90119-A0018 (m12x1.25x35mm)
Im doing the suspension this weekend and want to replace the hardware while im at it (and have a backup if I have to get out the grinder!)
Part number/size/pitch/length or whatever info you have!
Rear lower shock bolt
Front lower strut bolt/nut?
front strut tower nuts?
control arm bolts?
Lateral arm bolts?
Here are the head sizes... not sure if that helps you at all
Bolt sizes Front suspension
ABS bracket 10mm
sway bar end links 17 mm
tie rod 12mm socket
upper ball joint 19mm
lower shock mounting bolt 19mm socket (Install bolt from the rear, towards the front.)
Uppor shock mounts 14mm wrench
Bolt sizes rear suspension
Upper and lower shock mounts: 17mm wrench and socket
Brake line bracket to frame on driver side: 12mm
part number?
control arm bolts?
Lateral arm bolts?
Did you ever end up finding the part numbers? In the same boat and see so many different numbers listed?
Will
Will
Hey there. This is a little foggy as it was a while ago but....
Pretty sure i ended up with m12 x 1.25 25mm
I ordered them from bolt depot...
15246 Metric tap bolts, Zinc plated class 10.9 steel, 12mm x 1.25mm x 25mm
also ordered washers
However, The original bolts came out with no fuss so I reused them I think. THe bolt actually threads all the way into the the female counterpart. Think of the counterpart it as a spacer. The shock slides over the outside of the spacer, and the bolt screws all the way into the spacer, so only the bolt head comes in contact with the shock. Check this page and you will see a great pic of the bolt...
https://www.clublexus.com/forums/gx...ent-with-toyota-4runner-oem-replacements.html
Thanks. I ended up finding the toyota bolts. They are: 90901-19052 I believe. Hope this helps someone down the road. I found this site and they actually have really good diagrams to reference https://www.toyotapartsdeal.com/oem/toyota
Hey buddy, yes, all the parts that I ordered fit perfectly. I do remember though that I didn't really need them and the originals came out just fine, but nonetheless I replaced them anyways.
Perfect, thanks. I smashed the shit out of mine last trip out. Not even sure they're gonna come out straight, but the bolt heads are basically toast. haha.
