Replacement for '03 4Runner Factory Nav
Justiver
Anyone have any recommendations for an OEM fit navigation to replace the factory navigation in my 2003 4Runner V8 limited? The number on the front of the factory nav is 17006. I want a replacement that will fit in the existing opening without the use of a kit, has bluetooth, will work with steering wheel controls and factory amp, which I believe my vehicle is equipped with. A plug and play would be ideal.
Any recommendations and/or pics of your replacement unit would be greatly appreciated.
I'd check out Crutchfield. You can put in your specific make and model and they'll tell you what will work. I had a nav on my 03 and it quit working. A "kit" may be necessary, but it will look clean and blend in fine. I didn't bother putting a navigation unit back in there, but found a JVC that fit well, had good reviews, and played well with all the above accessories you referenced. It's since been discontinued.
Crutchfield told me I would need to install their spacer kit if I bought an aftermarket nav. I find it hard to believe someone doesn't manufacture an aftermarket nav that's a direct fit for my opening. Anyone have an other ideas for a aftermarket direct fit nav for '03 4Runner with factory nav?
Nav
I have a Metra in my 4runner its not fancy but it works. It just bolted into where my factory head unit was. Mind you I did not have nav to begin with so I don't know if that will make a difference or not.
