Replacing blown JBL sub (wire question)
alms_lefko
youll need to power it with a better amp if you want any kind of decent sound. Not the factory one.
Wiring at 2ohm is easy. See below
you have a similar one to what i have. With an aftermarket amp for the sub alone, youll have great sound.
And if I want to wire to factory. What wires do I use?
Going from memory, I beleive the stock sub was 1ohm DVC (dual voice coil.) By hooking the after market sub that is 2ohm DVC, to the factory amp, you would get half the power to each coil. Doubling the impedance, halves the power output. The stock amp is already really low power and you would be cutting down in half. You can meter the outputs to determine exactly what the rms is, guessing it would be really low in your setup. Like <25 rms probably. You want to get a new amp for your new sub. Install would be real easy and you can keep your stock amp for the interiors if you want.
Tx470
