Replacing drivers side door handle/lock
Redcat
My driver's side door lock got punched in over the weekend.
Luckily they didn't take anything, but now I've got to fix it.
I figure I need to order a lock cylinder, and a new handle.
The problem is none of the dealers look to have a green door handle in stock still.
If I get a used door handle, is the plastic paintable?
P.S. **** thieves
Sorry to hear. Yes, you can paint a used door handle.
Look on Car-part.com. You might find a green door handle off a 4Runner being parted out.
Salvage yard would be a good place to start. Call around, or like other post said, do a web search.
I just replaced my driver side key cylinder. I'll try to find the youtube vid I followed.
What year green? 96 to 98 is different than later years. Gateway wreckers in langley has a 97 green. I think it has the doors intact. You could call them. I want to go out sometime in the next few weeks when I can get time off work and could pick it up for you. I regularly cross the border to Blaine.
Mine is a 2000 4Runner.
I ordered one off of Ebay for $30 but it is a 1998.
I'll see how well it matches, and if it isn't close enough, then I'll either have it painted or continue searching.
Please be aware the ebay door handles are very soft (rubber like flexibility!). I bought 4 for my toyota sprinter (geo prizm) and those handles can be twisted easily even before opening the door.
Find a good used door handle. Apply anti-seize grease to the two 10 mm bolts that keep the handle to the door. It will make the removal easy next time!
The one I got was a used one.
PRWhite
