Replacing ignition / key
wrpsuite
Member
So my key has been hard getting in without jiggling and worried I'm gonna get stranded. Going to try some graphite but if that does t work can I have my cylinder re tooled to use existing key or a new one to use the same key so I don't have to re key door locks? Any info is appreciated.
you can get a new key made at the dealer using the vin. that is cheaper that buying a new lock cylinder. it just may be the key.
Don't use graphite!! Automotive locks use a grease from factory to lube them, although by now it may be all gone but none the less if there is some remaining the graphite will bond with those grease and effectively bind the wafers up even more.
The cylinders are super easy to remove, (explained many a thousand times before) your best bet would be to remove the lock and run it down to a locksmith and have him replace the wafers and cut a new key from code. This will by far be the cheapest thing to do, because of the split wafers in the lock you chance making them become completely jammed when you apply the graphite and it will cost a considerable amount more to get it fixed.
Yes some have had success with the graphite in the past but have just been lucky, if you don't trust any locksmith in your neighborhood just call AAA and see who they use.
Good luck
This is what I did...and it has worked great for the last 2 years and still going strong!! Worst case...if it doesn't work, you're only out $5.
Jhunt
