Replacing steering wheel with another Toyota/Lexus model steering wheel
LexusFTW
Has anyone replaced their 4runner steering wheel with one from another model Toyota or Lexus?
I know some of the GS or GX lexus steering wheels had wood trim that would look nice with the wood trim in the 4Runner. Has this ever been done?
I have not seen a steering wheel swap done on a Runner but anything is possible given enough money/time.
Air bag connection though would be a problem unless you plan on not having one anymore.
Here at the Lexus dealership I work at I have seen lots of take-off steering wheels and your right they would look pretty nice in a Runner.
i have a lexus/toyota steering wheel with wood. it would fit most toyota's and lexus 03-up. i bought it with intention to install on the runner it seems to fits fine never went threw with the process but wood didnt match with the grey fake wood around the truck it would of looked cheezy.
IF there's one that does swap in, use the same airbag connector, etc, like an actual direct swap, then I'd consider it because I'd LOVE some steering wheel controls for my radio! It's not a problem getting those to work, but I need a wheel with them first.
IF there's one that does swap in, use the same airbag connector, etc, like an actual direct swap, then I'd consider it because I'd LOVE some steering wheel controls for my radio! It's not a problem getting those to work (brother's a car audio maniac) but I need a wheel with them first.
Ditto.
I guess the ultimate issue with doing steering wheel swaps is the airbag. The airbags from other steering wheels are designed for different types of vehicles with different crumple zones, etc... which ultimately means that the airbag is designed to fire at a certain time that may not correspond to that of the 3rd gen.
Wouldn't want too early or too late of a deployment. If anyone can find information regarding the specific fire rate or whatever, we can find the closest match and hope for the best.
EDIT: Here's a thread I posted about this exact subject: http://www.toyota-4runner.org/3rd-gen-t4rs/90420-3rd-gen-steering-wheel-swap.html
Splines on the column should be the same. I met a Lexus tech with a 1st-gen Tundra who put a woodgrain LS400 steering wheel and kept the original Tundra airbag. I've also seen a Tundra using the same tri-spoke TRD steering wheel that's been used in Supras,MR2s,etc. so the splines must be the same.
Hi everyone am also have similar problem and i want to say that i bought a car only just tow months ago and i don't satisfied with its steering i want to replace it and buy new one if anyone recommend me good shop than i will appreciated him on this operating.
Hello folks, I've seen a lot of hit and miss info on the Lexus steering wheel swap. It's something I've wanted since I bought my 4th Gen and after talking to a Toyota tech I ordered a used GX470 wheel. The swap was very easy (just remember the airbag is literally an explosive device, haha) and I had it done in about 40 minutes.
Installation steps:
Disconnect battery, I waited about 45 min to start work
Removed covers on the sides of the wheel, they just pop out
Torx screws on either side lets the airbag pull out
Gently pry up the yellow clips and then unplug the airbag connections
Unplug the electronics
Remove the center nut but don't take it all the way off until you give the wheel a couple yanks to get it loose.
Another note, the Lexus wheel I bought had a bluetooth button but my 4R doesn't have bluetooth. The buttons on the wheel come off with one screw on each side and a couple little rubber nubs that just pull right out.
My wife's 2003 Sienna XLE had a JBL sound system with steering wheel controls. If I remember correctly, it was leather wrapped. I'd be very surprised if it wasn't a direct bolt-in. Everything else was the same -- even the ash tray, which I took because mine was gone in the 4Runner.
I like the look of a 3-spoke design. I would have it customized and wrapped in leather so that it would look like the attached pic
1998 Toyota Supra Steering wheel
Does anyone know if the 1998 oem Supra steering will fit in the 2003 4Runner. I mean it is do classic looking and I would wrap it in leather and make a flat bottom just like the Subaru flat bottom steering wheel I previously posted.
wayblom
