Replacing struts, what other parts???
cksutler
I am starting to gather everything I need to do the 5100 Bilstein lift with springs and was wondering if there is anything else I should replace with the strut assembly? I have purchased the Toytec washer and bushing kit and did not know if there was anything else someone who has done the suspension switch would recommend replacing when I have the struts broken down. Also, is there anything I should replace with the rear shocks when I switch those out? I would prefer to do it right the first time instead of going into it half-cocked.
I've got new FJ Cruiser springs, a set of four 5100's, replacement bushings for both front and rear sway bars, and new top plates/mounting hardware all around. I'm just waiting until the weather warms up a bit this spring before swapping everything out.
I've got a 2006 Sports Edition 2WD. One of my front struts is cracked and leaking fluid. I need to replace both, right? No lift or anything like that, everything is stock. What are the best struts out there? Bilsteins?
do you have xreas? if you don't know you can check by looking at the shocks. if they have hoses/pipes coming out of the shock body you do. if this is the case, you need to replace all 4 as the system is cross linked. the most popular choice on here is the 5100's for stock replacement, but there are other options, kyb, monroe, tokico, etc
seltzernator
