Replacing Tailgate: Quick Question
Yukon4Runner
Hello all,
I’m getting ready to replace the tailgate on my 2001 SR5.
Before I start poking around the local scrapyards, I wanted to make sure that a tailgate from any 3rd gen (1996-2002) would be compatible.
Thanks in advance.
Mechanically compatible, yes. If you don't want to swap the hatch internals, you should get a '99+ hatch.
-Charlie
Could you provide additional details?
I recently watched a video of a tailgate swap and no internals were swapped.
Do you mean, the internals need to be swapped if the window motor, plate lights or defrost on the replacement tailgate is not functioning?
Thanks.
Still have to swap internals.
Thanks.
I vaguely remember something about the wiring harnesses being different, but don't quote me on that.
Why?
I am with the majority here as well; get a complete '99+ hatch to make the swap easy.
I got a bare hatch when I replaced the hatch on my '97- after getting rear-ended. I had it painted, then swapped all the internals and wiring over. It really isn't too bad, but I would definitely try my best to get a complete hatch from the same year and color if I were to do it again.
Thanks.
Why?
1) the lock cylinder will be different.
2) the wiring harnesses are different.
I got 2 separate 99 hatches, one was a quick fix but had a massive dent in the side, the other was good, as in clean. No dents.
The harnesses were different, and when I would try to use my fob to lock and unlock the truck, it wouldn’t work. Neither would the window button.
The window worked when using the key, but not the buttons.
The harness I had going from the truck to the gate was the same, but the harness in the gate was missing a couple wires. Swapped the whole harness out and it was good to go.
I swapped our wrecked 96 rear hatch onto the 97 Limited puppy hauler. It was all plug and play except for rear key.
Breaking the rear headliner insert tee stalks to get to the harness plugs sucked.
Having a 6'3" 230lbs Sasquatch friend that can hold it while you do the wrenching makes it almost painless.
I can't explain the different '99s. In general, the '99+ internals are different because Toyota moved to a single Multiplex wire for communication between the Body ECU in the front and the Back Door ECU to carry commands from the the front to the back, together with going to a stock keyless entry with the receiver in the Back Door ECU.
The earlier units did not have keyless entry from the factory and commands from the front used separate wires for each function. Thus the liftgate internals are wildly different, both harness and ECU.
Different from what?
I asked "why" because your first post was super vague, and implied he'll have to swap internals regardless of everything. Someone said stick to a '99+, and you said "you'll still have to swap internals".
A 2001 gate falls into the category of a '99+, and I'd bet that would be a plug and play swap if both rigs were equally equipped.
Lock cylinder will be different, requiring swapping from old to new to use your original key for all doors
As I said the harness and lock cylinder are different.
Not 100% sure why the harness would be, but they are.
When I swapped my hatch, I had to swap out the harness to get everything to work right.
And there’s two harnesses. One from the truck, the other in the hatch itself.
The lock actuator or whatever it is that’s in the middle of the hatch had two wires coming from it to the main harness, where mine had three.
This was on two different hatches.
Whatever that single wire went to, it wouldn’t allow me to use my fob to lock and unlock the doors, or put my window down.
As far as the regulator and everything else, I BELIEVE they are the same, but don’t remember.
Ok, thank you all for the input.
The way I’m reading it is as follows:
To replace the tailgate on my 2001, if I find a ‘99+ replacement, I’ll only need to swap the lock cylinder so my key will work.
If I find a ‘96-‘98 tailgate, I’ll need to replace the lock cylinder and the wiring as it is incompatible.
Yes. They use the same part for the Back Door ECU, the orange one. '99 lists 85930-35060, but that is listed as replaced by 85930-35061, which is the listing for 2001. So it should all be plug and play electrically. (2001 and 2002 are clones, so it's all covered.)
Toyota Part No.: 85930-35060
RELAY ASSY, POWER WINDOW
Toyota 85930-35060 RELAY ASSY, POWER WINDOW
Part Description Relay Assy, Power Window, NO.1
W(KEY LESS ENTRY)
Replaced By 85930-35061
Manufacturer Toyota. This genuine Toyota part is guaranteed by Toyota's factory warranty.
Thanks again to everyone for the info.
I’ve found a 2002 tailgate in mint condition at a good price; of course it’s in a different color.
Anyone have any idea how much I should expect to pay to have it painted?
That depends on how good of a paint job you want and who does it. You'll get the best deal no matter where you go if you completely disassemble (remove seals, emblems, bezel, etc) the door yourself
Sent from my Pixel XL using Tapatalk
Hello all,
Thanks in advance.
I just replaced the hatch on my 2001 SR5 with a donor hatch from a 2000 SR5. I had to swap the lock cylinder and the ECU and now the keyless entry and the rear window work.
However, I have been unsuccessful in getting the rear defrost or wiper to work. I pulled back the rubber boot at the top of the hatch two of the wires in that loom had cracked casing but the wire itself was intact. I covered the exposed wire with tape to see if the exposed wire was causing my issue but no luck there.
Is this a wire harness compatibility issue or should I start looking at other components? Did you have any issues replacing your liftgate?
044runner4
